1. Install the file " ccnp_netsim7.exe ", REMEMBER AFTER INSTALLATION DONT RUN THE SOFTWARE "
2. Now go to Folder option in Windows , Click View and Tick Show Hidden files and folders.
3. Copy " mscon43demo.dll " to
c:\Documents and Settings\All Users\Application Data\Boson Software\Boson NetSim for CCNP 7.0 (WIndows XP)
FOr Vista & 7 Users, Copy "mscon43demo.dll" to C:\Program Data\Boson Software\Boson NetSim for CCNP 7.0
4. Run the software , select Demo version and let the labs load ,after labs are loaded ,exit the Program.
5. Then Extract all files in the ExtractME.RAR to
c:\Documents and Settings\All Users\Application Data\Boson Software\Boson NetSim for CCNP 7.0 (Windows XP)
For Vista & 7 Users, extract files to C:\Program Data\Boson Software\Boson NetSim for CCNP 7.0
Overwrite all the files.
Start The Program again ,select the demo version , let the labs be loaded ,Now you will get all commands and labs just like a full version.
BOSON CCNA LAB MANUALS ALSO INCLUDED
Link hiden,If you want to see please reply
http://rapidshare.com/files/347694238/BOSO706.rar
