Author Topic: 3Q:......  (Read 1556 times)
Offline bobnn99
  • สิบโท
    • View Profile
    • Email
3Q:......
« on: May 24, 2010, 09:30:46 PM »
Q1 By default, each port in a Cisco Catalyst switch is assigned to VLAN1. Which two
recommendations are key to avoid unauthorized management access? (Choose two.)
A. Create an additional ACL to block the access to VLAN 1.
B. Move the management VLAN to something other than default.
C. Move all ports to another VLAN and deactivate the default VLAN.
D. Limit the access in the switch using port security configuration.
E. Use static VLAN in trunks and access ports to restrict connections.
F. Shutdown all unused ports in the Catalyst switch.
Q2 : What are two reasons a network administrator would use CDP? (Choose two.)
A. to verify the type of cable interconnecting two devices
B. to determine the status of network services on a remote device
C. to obtain VLAN information from directly connected switches
D. to verify Layer 2 connectivity between two devices when Layer 3 fails
E. to obtain the IP address of a connected device in order to telnet to the device
F. to determine the status of the routing protocols between directly connected routers
Q3:Which Cisco Catalyst feature automatically disables the port in an operational PortFast
upon receipt of a BPDU?
A. BackboneFast
B. UplinkFast
C. Root Guard
D. BPDU Guard
E. BPDU Filter
Offline refeel
  • สิบโท
    • View Profile
    • Email
Re: 3Q:......
« Reply #1 on: May 25, 2010, 04:29:54 PM »
ANS.. B,F
ANS..D,E
A. BackboneFast
B. UplinkFast
C. Root Guard
D. BPDU Guard
E. BPDU Filter
ANS..D
Offline bobnn99
  • สิบโท
    • View Profile
    • Email
Re: 3Q:......
« Reply #2 on: May 25, 2010, 04:35:19 PM »
ขอบคุณครับ
Offline ปลาวาฬทราย
  • RMUTT CPE IX
  • ผ.บ.ท.อ.
  • จอมพล ขั้น5
  • Gender: Male
    • MSN Messenger - pws_admin@thaicpe.com
    • AOL Instant Messenger - ---
    • Yahoo Instant Messenger - ---
    • View Profile
    • ไทยซีพีอี
    • Email
Re: 3Q:......
« Reply #3 on: May 28, 2010, 07:54:59 PM »
get มั้ยคับ ???
ปลาวาฬทราย
RMUTT CPE IX
" มีแม่เหล็กอยู่ในหัวใจของคุณ ซึ่งจะดึงดูดมิตรแท้ แม่เหล็กชนิดนี้คือ ความไม่เห็นแก่ตัว และการคิดถึงคนอื่นก่อน เมื่อคุณเรียนรู้ที่จะอยู่เพื่อคนอื่น พวกเขาก็จะอยู่เพื่อคุณ "
Offline refeel
  • สิบโท
    • View Profile
    • Email
Re: 3Q:......
« Reply #4 on: June 01, 2010, 12:54:13 PM »
พี่ปืนอธิบายขยายความก็ดีครับ จะได้รู้ว่าผมเข้าใจถูกไหม  :)
Offline ปลาวาฬทราย
  • RMUTT CPE IX
  • ผ.บ.ท.อ.
  • จอมพล ขั้น5
  • Gender: Male
    • View Profile
    • ไทยซีพีอี
    • Email
Re: 3Q:......
« Reply #5 on: June 09, 2010, 07:33:44 PM »
Q1 โดยปกติแต่ละพอร์ตของสวิทช์จะอยู่ใน VLAN1 สองข้อไหนที่จะช่วยป้องกันการเข้ามาจัดการจากผู้ที่ไม่ได้รับอนุญาต
A. มันก็บล็อกเกลี้ยงดิ
C. มันก็คุยกับสวิทช์ยี่ห้ออื่นไม่รู้เรื่องดิ
D. ไอคนที่ไม่ได้อนุญาตก็เข้าได้อยู่อ่ะ
E. ?
เอาไปแค่นี้ก่อน ติดว่ะ 555+ เดี๋ยวต้องคิดแลปทำก่อน ;D
ปลาวาฬทราย
RMUTT CPE IX
